Custom/Hybrid Another great Watercraft Factory build!
waterfreak
I had a vision!
s florida
Just came back from the water test. well, the motor is absolutly sick and just kept spinning the prop. No choice now but to step up a a mag pump:biggrin:
time for a 144 mag:woot:
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Steve, Do you have a TBM pump stuffer in the stock pump?
If you don't have one, do that first...
nice gas tank mounting! beautiful work, everything is so clean and tidy. I noticed your fuel filters, i've had troubles with those flowing enough fuel with the big motors.
Yes, get rid of those plastic screen filters and use some big powersports paper hi-flow ones...
thanks!
Interesting!... I'll replace them and see if there is any difference.
my 1000cc would run well for a couple of mins then it would bog, it did it every time consistantly, and I could not figure it out for a while. I think those little stone type filters get plugged reall easy. I think some shavings from drilling the holes in the jazz tank were my biggest culprit,( thought I cleaned it out well but obviously not) I noticed malone runs those larger seadoo oil filters on his fuel lines, I found some factory kawi filter of a street bike and it solved the problem. Well anyway, might not be a problem, but figured i'd tell you.
crammit442
makin' legs
here
I think the sintered bronze filters are the ones that might actually have problems keeping up, as Tom mentioned. The ones in Steve's boat actually flow more than the ones you linked to. It's the same filter media type used in the Mikuni internal carb filters. Yours show 7.6 gallons/hour and the ones in Steve's boat show 8.9 gallons/hour. They also don't have any paper fibers that show up later in your internal carb filters like the paper elements seem to always do. Good quality filters! I buy them by the card at the local motorcycle shop.
http://www.itw-fastex-cva.com/images/stories/data-shts/visufilter/8426-00-9909.PDF :smoker:
Rickster
Matakana Menace
Yep, your onto it... Steve is definitely not using the stone or bronze filters.
Here are some pictures of the ski sittin high in the water.
waterfreak
I had a vision!
s florida
You think that the TBM stuffer will keep the prop from spinning like crazy? I am currently using a 12/17 big hub skat track prop. I was also going to try a 10/17 hooker prop but I think the result will be the same.
I'm not a big fan of the paper elements. I have seen them come apart over a period of time. Maybe I'll just stick to the OEM yamahas
RiverRat
Louisville, Ky
If you are having troubles now I think the hooker 10/17 will just magnify that problem. I would try a 14/19.
I have never had a issue with the filter you are using now. I have even run them on big sitdown ski's that drink fuel......no issues. I would make sure you run fuel foam in your tank. It sloshes easily and can suck air even when almost full
GIL
Power In The Hands Of Few
Cullman AL
Kinda reminds me of a 'knowledge bowl' in school. lol
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I don't use these filters but once a season on my 1000's, then replace with new ones so I've never had a problem, I've personally have used over 200 in the last 6 years. (I only broke a couple by making the lines to tight and bent the ends)
I know some of my customers have come back in for service 2-3 years later and still running these filters and no problems at all. I don't think that this company that makes these ones have the problems your speaking of them coming apart... so it's your call.
Yes, use the TBM 1st, and go bigger with the prop...Scat-Trak 14-19 -3 big hub should help you get in the ballpark. I run bigger than that on my 8mm strokers and no problems with the TBM. Start with the medium cone as they come with 3 cones! This way you can tune either way.
Are you running a bored out nozzle?
Now if cost is no problem...order a new billet mag pump Monday as you won't beat the performace that a Skat-Trak Magnum pump gives you!
GIL
Cullman AL
It amazes me that someone would run a $10,000.00 motor and not maintain it, ie spark plugs and fuel filters.
waterfreak
I had a vision!
s florida
Yes, it is at 85mm
