Custom/Hybrid Another great Watercraft Factory build!
waterfreak
I had a vision!
s florida
how is the pad held down? glue'd to the hull?
i would do a strap over the chamber for sure!
from one of the waterbox mounts to one of the gas tank mounts.
It's glued down with contact cement.
Once I get the tank, I'm gonna put a strap down
Roo
it's all good
good deal!
will you be at Daytona with this boat I hope?
really would like to see it in person... local riding buddy of mine has been eye balling your hulls / site quite a bit lately.
waterfreak
I had a vision!
s florida
Braappp!
hell to the braapp!!
Well. after wondering what the hell was going on with the timing, I found the MSD took a shizzle. I replaced with a the one in my white boat and....Holy crap!!!!!!!!! this thing sounds nasty!:hail:
I pick up some VP c-12 today because the compression was at 240 psi and about .042 squish . As soon as my Jazz tank arrives, off to the water I go!
:brap::brap::brap:
SUPERTUNE
Race Gas Rules
Clearwater Fl.
You better be VERY CAREFUL with that kind of compression with the PFP pipe and using a MSD Enhancer!!! Just remember you basically have no timing retard, so don't take it out until you put a timing light on that thing.
waterfreak
I had a vision!
s florida
finished!!
:Banane09::Banane09:
Finally completed!! The final piece of the puzzle was the new Jazz gas tank!...thanks Brian!! (thrust innovations)
If the rain stops today, I will be water testing .
What size straps did you use for the tank? Is it two of the "long" tank straps or the short ones?
