OCD Solutions
- Rentz, GA
I need to understand how this happens so it doesn't happen again. It is a seadoo 951 Ported and bored out 4th over. This engine has less than 4 hours on a fresh rebuild, had 165psi compression to start and the plugs were always a nice color. I always ran Amsoil Dominator oil mixed at 40:1 with Premium fuel. I have some ideas but I want to see what some of you engine builders spot and figure out.
The port job was done by a Skidoo guy that may have assumed that certain concepts cross over that maybe do not? 1mm wider and 1 mm higher on the exhaust port was all the specs I got. Ring end gap was .016" and piston clearance was 0.006" (measured roughly with a feeler gauge and divided by 2, not the best way but all I have.)
Not sure if its needed but I was running a Rossier head with 49cc domes, Novi/Dean intake with dual Novi 48's and a Coffman pipe. Advent ignition with Coffman pipe timing curve.
Anyway, let the CSI'ing begin.
