highroller customs Stunt hull build
hi, i just got my new hull a few weeks ago from Dan Stein at high roller customs... im super pumped! im transplanting my 10mm lamey PV motor, 900cc, 49 full specs,,,with MSD total loss... was gonna get crackin and try and ride this bad boy before the freeze? but got called bact to work, and have no time now!!! so, it may be not seeing water till spring,,,, ill keep posting with progress all fall/winter.... :arms::arms::arms::arms:
yea,, its definatly short,,, but its alot wider too,,, i wanna get my motor out soon and set in here to get an idea of what water box, and exh outlet im gona run...
How do you like the build up of the hull, good craftsmanship?
yes,,, its built well,, fells very stong, very ridged,,! its white gelcoat now, and the only kinda negitive is it still ,,needs wet sanded and buffed, but im painting mine black.. so it shoud look like a factory build ski when its done... very happy with my purchase.....:veryhappy::veryhappy::veryhappy::veryhappy:
yamanube
This Is The Way
Staff member
Mandalor
Agreed... The only evidence I've seen that this hull actually had a hood made for it was a picture from far away with an unpainted hood on the prototype hull.
And a couple wierd angles on his website that show the front 1/4 of the hood.
