Little too much white smoke?
Would months old gas cause this? It has sat for a couple of months, started it here and there, know I'm finally finishing it and gave it a start on the rack. Lots of white smoke , and hangs around after too. The carb setting are fine, ran all last summer and part of this one good ,but but this woories me.
Well I just pulled the plugs and are super wet, can't beleive it starting so quick. I just installed a new primer and was squirting a bunch of gas in the carb, would this cause them to foul? That's the only thing I can think of.
Motorheads5
Livin the generation gap
ketchikan alaska
You need to take it out and run it build some heat in that motor, you probably have a 1/2" of fuel / oil in the bottom of those cases. Then see what you got.
