2x2 carbon for installing footholds
JustinB
Proof I has a brain \l/
Oxford, MS
I installed my Rickters using what I had on hand, which was 6oz 2x2 twill carbon. For epoxy, I used Max Clr. I only did two layers and I am worried it will be too thin when I sand it all down smooth. Should I add more layers? I do have some cheap glass from Walmart I could put over the top if I need to.
SuperJETT
none
Sand it down and see if it's too thin, add more layers if it is. It's hard/impossible for us to see how thick something might be based on pics. I do think you should overlap more though.
JustinB
Oxford, MS
I guess what I am asking is if two 6oz layers is enough before I sand.
Waternut
Customizing addict
Macon, GA
I think I used two layers of fiberglass tape that was about the same weight as your carbon but I also rivetted the holds into place. I figured the rivets would hold most of the load and the fiberglass was just a sealer.
JustinB
Oxford, MS
Mine are riveted in too. I screwed them in when I epoxied them, and then filled all of the screw holes with rivets (plus a few more).
MN
Why? I had the carbon already, and glass wouldn't be stronger or lighter.
actually,.. the glass you purchased from walmart would have actually been lighter. you used 6oz carbon, walmart probably sells E or Sglass woven mat which is probably 1-2 oz lighter. Not to mention using carbon for that job is just serious waste of money.
JustinB
Oxford, MS
It already had the carbon, so it wasnt a waste of money :)
