- Clearwater, FL
today a guy gave me a UMI Steering system for a blaster. Unfortunately I can't get it off the hood. I've got the guys hood and I'm trying to get it off the hood so I can give him his hood back.
I took the nut off the bottom of the steering shaft thinking the whole shaft would just slide out from the top. Well it won't. I thought it was supposed to just slide out. Is it pressed on to the bearings? There is definitely some corrosion on it so I hope its not locked on there.
I'm just wondering what the proper way to remove the steering system is. Also what parts will I need to replace to rebuild it and make it like new. I know I need to replace the o-rings and bearings, but is there anything else I need to replace. I heard there is some sort of plastic piece I'll need to replace.
Thanks for any advice,
Dan
Dan
