You should expect quite a bit of difference but unfortunately you should also expect a huge headache while installing and tuning it.
It depends what you call a headache, we provide them with pre programmed curves if required so there is no real tuning. As for the installation, you fit the stator (pick up is already fitted) solder three connections then the flywheel, set your static timing and fit the ECU in your electric box using the OEM wiring harness and OEM connections. If you do find this complicated, probably best get some help but we are only a phone call away.You should expect quite a bit of difference but unfortunately you should also expect a huge headache while installing and tuning it.
What can I expect from a total loss ignition on my B-piped and freestyle(LPW)ported 701?
At the moment I'm running an MSD enhancer and a RAD charging flywheel.
I'm very interested in the ATP setup that uses the stock elec box.
Thanks.
If you are already running a light flywheel and you are looking for more then you need some 61x 760 jugs (surfersmurf selling a nice set up right now) or a team scream motor IMO. How is TL gonna help that motor anymore than its already been helped. You need more CC's IMO. I don't know much about TL but I would think the most massive gain from it would be its 2lb flywheel.
Isn't the biggest advantage that you don't charge the battery and that the magnets in the flywheel has a lot less resistance.
I think it's similar to an alternator in a car, you need a lot of force to turn it over.
The force you normally need there you have on the crank.
I read that he's referring to the MSD Tl system...Not Chris's ATP system!
Thanks.
