- Lake Stevens, WA
Just did a 144 Pump Convert. Running Hooker 10/16 -7mm impeller. JD Intake and Protec (modified) ride plate. Motor is bone stock. It has been recommended to me to: "ADA head, porting, B pipe, advent ignition" for the next set of mods to help spin that larger pump / impeller.
Questions:
1. Pipe swap first?
2. Assuming Pipe swap . . . If I am not interested in top end (I'm not) and looking mainly for low end grunt, do I really need the ignition? The Advent is really expensive. If the ignition is needed, can't I solve with a stock set up modified by Protec? Recommendations please.
3. As for the head . . I want longevity out of my 61x motor. My thought process is to avoid the head, keep the RPM's lower (assuming it doesn't cost low end) by not doing the ignition mod . . and see if the pipe will give me enough. Is my logic flawed?
4. My ski has a one way valve in the back. After hard riding . . in never have more than 1/4" of water in the hull. I do not have a bilge pump. I assume if this valve fails (ever heard of this happening?) my ski will sink (assuming I am not moving / can't get it started when out from shore). I really don't want to have another control on my handle bars . . any one gone with a float type of bilge? Only looking for it to kick on in such an emergency situation where the hull is filling with water while I'm filling my paints trying to get the ski started.
Thanks in advance for any guidance you all can provide.
Questions:
1. Pipe swap first?
