Square exhaust tube removal
QuickMick
API 1104 AWS CWI
Someone at the lake asked me yesterday about removing the exhaust tube from the rear of his square. The aluminum one from inside the tray.
I couldnt completely answer his question.
He wanted to know if he drilled the rivets from the back of his ski at the exit of his exhaust tube and cut the glue (5200) from the neck of the tube would the thing slip/pull/come out?
He thinks he has a leak between the exhaust tube flange and the rear of his ski.
His ski is stock and has never been refoamed.
SuperJETT
none
If it's original and had a leak, it might just drop right out once the rivets are gone. Otherwise use a block of wood on the end and beat that with a sledge to drive it out the back.
