Kawi 800
06' SXR
- Harveys Lake PA
Ok so i took my pipe off to get the hole fixed. Fixed it, put the pipe back in and now it wont start. Its not doing anything, i hit the start button and nothing no sounds no clicks nothing at all. Checked all conections, pulling the battery, charged it up, the bildge pumps work no problem but when i hit the start button i get nothing. Pulled my ebox, noticed the fuse was bad inside. changed it with the stock fuse that came in the ebox. put everything back together still nothing. it will turn over if i touch the positive battery cable to the stater cable. but when i try the switch nothing happens. Now i did notice that my start wire from the switch was coroded (sp). so i cut the bad out but where it connects to the ebox to the switches it is still bad looking, could it be that i need a new switch?
Cale
Cale
