- New Jersey
my friend has a 701 that he just had the crank seal redone on and they have less than a tank or two of gas on them and he blew them out again. what could his problem be?:Thinkingof_:
the Yamaha book says to keep the outside of the seals dry and use grease on the center.
BTW, did you install a rebuild crank recently? I have seen the rear circlip on the rear bearing, be too big and not allow the cases to close properly and blow the rear seals.
