- St.Louis Missouri
I just picked up a 48mm Mikuni that was used on a 750ss and Im curious if this would be a good setup to use? I have a 61x engine, with a Factory B pipe, 185 psi girdled head and MSD enhancer. Right now I have the stock carb that came with the 61x(Is that 44mm?).
I really have no clue on what this carb exactly is...it has a purple adapter on top. I can get some pictures later if necessary..the body of it is a silver color.
Any insight is appreciated.
Also, I would need to buy an aftermarket intake manifold correct? Or is it possible to "bore" out my manifold opening to match the opening of the carb?
