Is the heat range higher as the number goes down or up? Ex: Is a B7HS hotter than a B8HS or a B9HS? AND- Does anyone know the difference between a B7HS and B7HS-10? They look identical.
about a year ago i tried b8s in my x2 that uses b9s, was out of water cranked it and the engine was predetenating, plugs ignited the gas without the pistons up and i allmost blew it up, but i pulled the boots off JUST IN TIME
