ok how exactly do i find out which one i need then?
I have set up stock carb 6M6/701s with stock and ported cylinders. All of these required a 120-130 pilot depending on popoff and pump load. Its a fairly safe bet to start with a 125 pilot, 65 gram spring, 1.5 (stock) needle, and A 150 main with 2 turns out on the top screw. For best response use a pilot that makes the engine gurgle slightly at 1/4 throttle.
