http://www.confickerworkinggroup.org/infection_test/cfeyechart.html
Conficker Eye Chart
How to interpret:
If you see this above:It probably means this:
= Normal/Not Infected by Conficker (or using proxy)
= Possibly Infected by Conficker (C variant or greater)
= Possibly Infected by Conficker A/B variant
= Image loading turned off in browser? Any other combination= Poor Internet connection?
Explanation:
Conficker (aka Downadup, Kido) is known to block access to over 100 anti-virus and security websites. If you are blocked from loading the remote images in the first row of the top table above (AV/security sites) but not blocked from loading the remote images in the second row (websites of alternative operating systems) then your Windows PC may be infected by Conficker (or some other malicious software).
If you can see all six images in both rows of the top table, you are either not infected by Conficker, or you may be using a proxy server, in which case you will not be able to use this test to make an accurate determination, since Conficker will be unable to block you from viewing the AV/security sites.
Conficker Eye Chart
How to interpret:
Explanation:
