cookerq62
Life's Been Good
- Upper Bucks, PA
Did you leak test your ski before closed it back up? When I did my square nose I hooked a pump up to the hole for the foot hole foam and build up some pressure then marked all the leaks, put a dab of 5200 on each then applied a vacuum. You just repeat the process until you can't find any more leaks. I for the life of me could not get the exhaust tube on the inside to seal.
