oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
So this is the first time I have ran across this type of problem.
I installed the pump, and can get it aligned up and down just fine, but as you can see in the pics, the drive shaft sits in the hole closer to the carb side of the boat than the exhaust side of the boat.
I have never come across this problem before. You can't really twist the pump to compensate for this problem b/c there are dowel pins that go up into the ski that don't allow it to shift left/right. I guess I could remove those dowels, but I would assume they are there for a reason.
Any advice is welcome. Thanks!
