cf inside the hull
so i decided to reinforce my hull with cf.... the problem is the inside is painted with black paint that feels weird(kinda rubbery) what is the best way to remove this paint and the best tool to remove the ribs... Let me know! also how much cf should i order to do this and what kind?
Thanks
Sospikey
Trying to get upside down
Sweden
Thanks
Either chemicals or wire brush. Try using thinner or acetone. If it doesn't clean off easily, bring out the wire brush. Remove the ribs with a rotating sanding disc. Use a mask and try doing it outdoors. It is messy...
