are there any advantages of 750sx over sxi or sxi pros in terms of turning it into a freestyle ski? i care a lot more about bottem end then i do top end. if i had the loot, i'd get an sxr, but i can't afford it right now.
thank you.
The '98 and up are SXI Pros have a hand-laid fiberglass lower hull, but they also went to pre-mix only to drop weight. There are a couple handling advantage to the "pro," including slight hull changes, the motor is mounted further forward, there are small sponsons under the rear rail, etc. All of this probably wouldn't make a difference for freestyle. They are supposedly the same weight as previous 750 years but I call bs.. my buddy's 98 always felt like a tank compared to my old '92.
Your sweet spot weight and budget-wise would be a 96-97 SXI because it has the same bigpin motor used in later years. The '95s are also dual carb but have a less powerful motor. Of course, I can't really diss any year 750- my previous one was a '92 single carb and it was a great ski too. My current one is a '96.
SX= 318 lbs (63 hp I think)
SXI= 329 lbs (75hp, '96 and later)
SXI PRO= 329 lbs (so they say)
SXR= 351 lbs
All seem a LOT cheaper than same year superjets, at least in my area.
Hey, I'm also in the East Bay CA
