the WaTeRhAwK
fryin' up a/m electrics..
- okc
xKawi550x - which color sbn carb did you buy?, was it new, or what's the history on it that you know of?
just admit it..... You really love matt.
You will need to remove the diaphragm cover, diaphragm, jet cover block, and then both jets.
The bigger main jet will have a number written on the side.
The pilot jet will have a number written on the bottom face.
Those are your jet sizes.
You should also remove the popoff arm & spring and the needle valve to determine what size it is (written on the face of the valve seat).
I'd advise you to read the manual I linked to.
It should answer most of your questions about these carbs.
it's the silver spring, and I had to cut two coils off of it to get it to the right setting.
xKawi550x - you definitively want to measure popoff pressure with a gauge if at all possible. Just going by chart in the manual can be inaccurate, as Waterhawk's example illustrates.
