My WaveBlaster Budget Surf Boat
Aircraftsalz
Thrust built Dasa Power
Off site
Starting my Budget Waveblaster Surf Boat today,
Picked up a 93 Waveblaster 2 wks ago, All stock in running condition $150.
(Guy couldn't get it to start, Drained the old gas & it fired right up)
Picked up a Ride plate & grate from Seatsr4toilets $100 (Installed Today)
Ordered Pro Taper Bars & 1 1/8 mounts $100 (Installing tomorrow)
Footstraps from Blowsion $50
Rule 500 $50
Total so Far $450
Going to install the footstraps next week. Still looking for a Pipe so I can install the 5mil Pro Tec motor I have sitting here! Should make a great surf boat!
BruceSki
Formerly Motoman25
Long Island
sweet deal... steveuk is selling a blaster mod pipe pretty cheap here.
there are a few people selling riva reds and protec pipes on pwctoday.
Aircraftsalz
Off site
Thanks I'll search for it, I'm thinking FP with that 5 mil motor. I had it set up in a SJ with FP Mod chamber & it hit hard. I keep hearing FP limited chamber for the B1, also have heard good things about the Riva Red pipe.
I'm trying not to spend over a 1K on this Ski!LOL
BruceSki
Formerly Motoman25
Long Island
i heard the riva red is good too, just gotta worry about leaking, falling off, bolts rattling loose and its heavy.
factory pipe is the best way to go for any ski(power/reliability wise)... they have the market cornered.
Aircraftsalz
Off site
Pipes
I run the FP mod pipe on mine, best thing I ever did!
Is your motor stock 61X single carb or 62T with duals? I was told the FP limited Blaster chamber was better on the bottom end. Next week I'm going to pick one up!
Tomorrow I'm installing the Pro Taper Bars & mounts. Will post up PICS tomorrow.
Aircraftsalz
Off site
Pro Taper Bars 1-1/8 mounts
Installed the bars this morning. The Pro Taper Bar mounts give another 3/4 rise, So with the Travis Pastrana FMX bars I got the rise I was looking for.
Aircraftsalz
Off site
5 Mil Pro Tec Stroker Motor
Almost have the 5 Mil Motor ready to install. Here are some pictures of the motor. Just waiting for a Pipe & my Dual intake. Should make a great surf boat!
Aircraftsalz
Off site
PICS of Motor
Motor
Aircraftsalz
Off site
Pipe
Picked up a Pro Tec Mach 1 pipe, Should have it by Wed. Motor is ready to install, Just put new crank seals & Pro Tec head on. Hope to get my dual intake by next week. Foot straps arrived, going to install this weekend.
Only have 9 days to get it ready for Slutfest! Plus my SJ needs carbs!
Aircraftsalz
Off site
foot straps
Got the foot straps installed today. That foam SUCKS! Made aluminum plates for top & bottom, should hold up. Motor is ready to install, just need the Pipe! Should be ready to go for Slutfest!
Aircraftsalz
Off site
5 Mil Installed & Ready for Test ride
Got the 5 Mil Pro Tec motor installed today, Motor fired right up. I still have to get a MSD box, I still have the stock CDI box. Couldn't use the water box with this Pro Tec Pipe, so for this weekends Slutfest its going to be NO WATER Box! I got a raider that I'm going to pull the water box out & do the rear B1 waterbox.
Here's some PICS.
Aircraftsalz
Off site
Water test
Did a quick water test today to make sure it was good to go. This motor set up was made for the blaster. It hits hard on the bottom & still has great top end. Should make a great surf ski. All I need now is a msd enh. or modified CDI. Mcdog is sending me a CDI box which should help. This motor hits the stock rev so quick! Will have pics tomorrow from Sebby Slutfest!
Aircraftsalz
Off site
how do'es it sound without a waterbox.
Way to loud, but I wanted to ride that weekend! Right now I'm installing a Sea Doo 720XP water box. Will post up some pics once installed.
Now it needs a Prop, with the 5 mil its wide open at less than half Throttle! But it gets there real quick!!!!!
