leprechaunjohn
john john the leprechaun
- Mobile/Auburn, Alabama
anyways back to cornbread build,,, good luck ill be watching
Thanks man, just put 2nd layer of glass down as well as reinforced tray ( hold to hold). Gotta wait for it to cure then i will throw down the 2nd layer on foam holes and safety tail spray hole.
Then it will be on to mat and turf (Not looking forward to this at all):thumbsdown:![]()
take your time when you turf...
i think its best to turf with two people... do the two gunwales, then bottom, then dash last.]
hmm, I do bottom, front and then sides last.
I got a kit with the holds from blowsion and it recomends to do the bottom first, sides. then dash.
Probably just personal preference, either way i know its gonna be a PIMA!!
the 08 sj already has a low pitched ss impeller and higher compression straight out of the crate from yamaha.
Higher compression? Really??
Thanks Pete, i was seriously worried, it took a few cold beverages to gew the nerve to attack by myself for the first time!!!!!Great Pad and turf Job !!!!! :bigeyes::djsmilie:
