Foximus
CFL Cheapass.
- Oviedo, Fl
I just bought bike cables that are stainless.
na. I'll buy it.
after doing a little research into the above statement by special fx I have decided to not use my trim lever setup . However after considering the type of riding that I will be doing (wave jumping ). I will be using my backup plan trim tube only . Since it pretty much bypasses the trim cable system anyway I wont have to worry about the cable bending in half.I did a similar setup on my FX-1 (which uses an X-2 pump/nozzle) and it works great dry, but under pump pressure the cable stretched like a rubberband and did nothing. When I pulled the lever it felt like it was working, but the nozzle never even budged.
I hope you see better results.
