How u guys get a twin 1000cc in your SJ ?
I want to know the best way to get a big engine in my superjet for freestyle .... I dont get it where u all get 1000 cc engines!? A big bore kit for 61x cyl just make a 780-800 cc bore ... does this worth it? and I 'm from Quebec near us lines in Canada ... so there are almost no pro jetkier down here to help me. Thanks!
SuperJETT
none
10mm stroker crank plus 90mm equals 992cc.
Or the EME 1000cc engine, or the Waterdawg 1200cc engine.
equals 992 this is a cylinder? And u must run 10mm stroker crank with this cylinder if I understand... and this crank fit 62t base? If yes then I need to machine the base so new 992 cc cyl will fit? What about the head? I want to know more!
Randy at Watcon.com has a brand new 10mm billet stroker from Crankworks
cheaper than new. This along with a huge lamey or the ADA (thats on sale)
will give you almost 1000cc. Randy's # 360-692-3492
wsuwrhr
Purveyor of the Biggest Brapp
I would like to think it is the best way, but there are also other ways as well.
Dasa/Lamey 90MM big bore aftermarket billet cylinder, throw in a 12mm or 16 MM stroke will get you were you need to be.
Brian
wsuwrhr
How about 1200cc?
picture.php
waxhead
wannabe backflipper
gold coast
yeah im thinking a low end engine with a tall prop
its not the sort of thing your going to be reving to the moon
But that would actually make a good race engine
It would just grunt its way around the track
wsuwrhr
Could we see a picture in the plan view without the cylinder? How does it look?
what mains are used? GPR? or STXR?
It looks AWESOME!!
I don't know exactly what you are asking. Let me know what you want to see pictures of.
The case uses Superjet mains, ANY SJ crank you have will fit in the case.
