- Colorado
Alright so I am throwing a 701 in my x and don't want to roll a modded plate. I want to grind the hull and glass fixed mounts so I can use the 701 bedrails. I was planning on making a metal frame for the yamaha mounts to attach to and placing them with industrial epoxy. then glassing or laying carbon over that. has anyone ever ground out all the ridges? I was going to go up the side walls about 6 inches, this gets past the bond line anyway for reinforcement. Will this be sufficent, or am i going to compromise strength? What type and weight material would you suggest? thanks in advance
