- Alabama
Just kidding its a J/K........ :biggrin: I am in a funny mood today. :biggrin:
Mark44
It wasn't directed directly at you well not directly that is lol:Eyecrazy:
Mark44
The only torque the bulkhead sees is what is created by the drag of the intermediate bearing/seals which is fairly minimal.
I can understand if your foam is waterlogged from years of riding, but you are starting fresh. Just put some nice new foam in there, and you are good to go for ten more years.
Honestly, taking all of that foam out would not really have a positive outcome in my opinion... The amount of foam removed would equal what, 5-10lbs max? In effect you are just making your ski that much more prone to sinking. As I am an engineer (not as far along as Dustin, good luck on the PE!) and am cursed to think like one, I think most people don't realize that the foam does not make the ski more buoyant, it just makes the fillable volume inside the ski smaller. A hull full of foam will float just as well as an empty hull, only difference is when you submerge the hull full of foam, the foam is displacing a large amount of volume for its given mass. Seeing as how all jetski hulls are anything but watertight when you submerge them, if you submerge a ski with no foam, less water is displaced for the mass of the whole, and you have a ski that will sink to the bottom like a rock. A good comparison would be to imagine (or try it yourself) an empty beer can. If you were to fill the can half full with foam, and then try and sink it, it will probably still float with a large portion of it above water. Now try the same thing with an empty beer can and no foam.....
Comparing my HX to the configuration of the SJ, I wish I could fill up the empty space under my footwells with foam, but then it would be a huge pain to remove exhaust hoses etc. In my opinion foam is a good thing, and very cheap insurance. I can understand if your foam is waterlogged from years of riding, but you are starting fresh. Just put some nice new foam in there, and you are good to go for ten more years. If you are hell bent on pulling some foam out, I still think the best compromise would be two lengths of 2" PVC pipe (just like a scupper setup...). It will give you your desired result and keep some structural integrity.
Just my 2 cents
I think people are missing the point, it's not that I'm taking foam out because I plan on foaming the nose to replace most of the missing foam, it's that the area under the tray is where all the water leaks come from resulting in waterlogged foam. So, I want to keep that area open and even serviceable if need be.
The upper deck gunwales will be foamed and glassed over prior to assembly, so it won't leak. The nose will be done the same way so it won't leak. My handle pole has foam and I use 25mm underpad which adds floation as well.
I posted this quite a while back and I got a bunch on negative responses.
I really don't care about sinking. I have TONS of insurance and in my life have never sank a ski. And if I do that is where the insurance thing comes to play.
I would do it in a heart beat. It is the smartest thing you can do. never have a foam problem again. I would also mount dual scuppers in the back. What are the chances that a ski quits running and the battery is dead or the bilge pumps lock up all at the same time. I know that it can happen but what are the chances.
Here is my old thread http://www.x-h2o.com/threads/38516
BTW, I have plenty of experience with buoyancy, etc. I've done a few rough calculations based on hull side/thickness/weight and feel ok about things at this point.
pingpong balls dude...![]()
I didn't see or don't remember your old thread, that is interesting.
I honestly can't recall that I've ever completely sunk a ski before, though I've helped bring in others. I know it can happen though.
you never sunk a ski living in Hawaii???
sinking a ski can be nothing more than going off for a stab, having the hood come unlatched and before you know it she's sinking despte bilge pumps
without nose or pole foam my 367lb ski would float a couple of inches UNDER the surface and bob down out of sight.....You'd have to tread water next to it and hold it to keep it above the surface
Never have sunk the fx1..I attribute that to the foamed pole and hood desgin....In fact, it wont eben flip upside down...the pole will right the boat lessening its chances of getting swamped
