rick roy pole ?s
new jersey
does anyone have a RRP set up on a surf/freeride superjet? is it really worth all the money? (i am only considering the pole because i am a large rider at 6'3 225 and i am not to sure on what length pole would be best for me) i love the look of the RRP but i just don't want to spend all the money and get the same results i would with a regular aluminum pole....also besides a chin pad and a turn plate and a optional mounting bracket, what else do i need to actually use the damn pole??
thanks, nick
stanton
High on jetskis.
atascadero,ca
lots of people have rrps for surf, i can think of 5 people i ride with that run them.
only downside is the modification to run a spring.
and i think you have to run the rrp bracket too...
I would say it's the most overrated, overpriced thing you could buy for a ski. Jmo.
heavy and expensive.
I would suggest a short steer plate and bars setup (2.5" or -3.25'), and cutting a stock pole down, start with -2". If you want it even shorter, cut another 1" or whatever you think at that time. I am 6' and have ran everything from stock to -9.5". And for me -7" overall is about perfect. But my setup can be hard for short people to ride. The main reason for my short pole setup is the fact that my overall ski is pretty light, and very light in the nose (about 22lbs lighter from the battery, tank and waterbox setup alone).
If I was at stock length I dont hink I would be able to bring the nose down after landing on the tail in surf.
Stock= super light, any length you want it, and cheap.
RRP= 5lb heavier, 15 hundred dollar turd.
There are so many better things you could spend you $$$ on.
Oh, and when you find the right length on your stock pole, I stongly recomend wrapping the lower portion of the pole with some 11oz Carbon... Keep the weave tight, and make it 3 layers thick, overlapping the metal as far down as you can go, and 4"s up the fiberglass.... be sure to realy scuff everything up with 40grit, I remove all the gelcoat when I do this, keep the resin content low by squeging out as you go.... I abuse the hell out of my boat, and I can not breat this pole setup.
I run a x-metal stainless bracket, and no pole spring also. The bracket allows me to tighten the pole movement as much as I like... Billet brackets do not allow this.... you could also run a spring as well.
I dont like the tight no spring setup with a x-metal pole, its just to heavy for me.... stock pole all the way.
Scorn800
Ride for life
North NJ
RRP pole is great. Well made and easy to change length.
I'm using the oem sxr bracket & oem sj chin pad with jettrim cover,
Best pole on the market :Banane09::Banane09:
If I were building another ski, an aftermarket pole would be pretty far down on my list.
That said, I like the looks & functionality of the RRP pole.
Thats the thing that kills me, you spend all that $ then you still need to do mods to be able to hold the pig up.
And out of those 5 people how many of them are sponsored, or got the pole for cost or cheaper. :pokey:
I do like the looks, but that is it. If it was a 8lb pole like a stock round nose my opinion may be completely different..... but its 13lbs, heaviest pole out there.
z00m
UK X-H20
UK West midlands
I made my own it cost 20 pounds in alloy and a bit of work to get right , and its light and very strong,
PS EGNORE THE DATE THE WIFES CAMERA AINT SET UP LOL
Mick
stanton
High on jetskis.
atascadero,ca
noone would run them if they had to pay full $ :lmao:
i dont like it, it works and all, but the design just has too much investment to be cheap.
oh and i have seen coung break a couple. hes not had that problem scince going to a rrp bracket though. jfb runs one with no limiting rope!:headbang:
Mick
That beast is pretty sick! Did you get a weight on it? I would rock one of those if its light, and you lived in this country.
I agree with Cracker,if you have ANYTHING else to do to your ski do that first and mod your pole with some heavy duty rivits and reinforce like he said,after you find the right length,then get a very affordable xmetal bracket, another plus on the stocker is... its foamed filled and will right your ski in the surf when it gets away from you and turns upside down even xmetal poles suck in this respect
