Stock 08 rideplate
750SX
DO IT
Palmyra
Will a new 08 rideplate fit the 96-07 superjets? I think it will just have an extra set of holes in the center, and the rears will have to be drilled out. Am I correct?
The reason I'm changing is that I am currently running a square plate, that has the adjustable bosses in the rear for shimming the plate. I do not like how low the bolts hang down from the bottom of the plate. I'm hoping that the bolts are more recessed in on the 08 plate, if it will work.
Thanks!
oxnard111
Creative RE Purchasing
Thanks!
i have the same problem, running a square plate, and the bolts stick way down. I put in rounded allen head bolts, but it still snags the carpet on my work stands and trailer.
I think the the holes are recessed on the 08's but I can't be certain.
