I see people posting that they are going to use extruded polyestrene foam and bottles and pinp pong balls instead of foam but have never actually seen a build with this in it? Has anyone ever done it or just talked about it?
Totally unbiased, but something doesn't look right with that foothold install. And not knocking on Steve, but I wouldn't have installed those paper thin footholds to begin with. What did you think was going to happen? No offense of course.
And at least they cracked and stayed installed, instead of completely ripping out, hydroturf and all :wall: :laugh2:
Everyone take your ping pong balls and boogie boards and coke bottle and make your own thread.
I'm using marshmallows this time around.
are you going to install them precooked or a little charred? what about the Chocolate and Graham Crackers?
Well then, what is wrong with the install??? Darin was one of the first guys over at PWCToday to install footholds, throw on a lowered freestyle hood. He has been installing footholds longer than most of the guys here. He knows how to properly install footholds. Trust me, there is nothing wrong with his installation.
Back in post #80 I posted a pic of everything glassed up and ready to foam. http://www.x-h2o.com/showpost.php?p=96727&postcount=80
Darin when did you purchase these footholds? New when purchased?
Steve have there been any design changes over time with the footholds?
Have they always been painted? I recall mine being black but I thought it was dye in the resin.
Doug
there you go! the bi-axial is on on the edge of the foothold where it still has support from the pump cavity. You need it to go inside the hold all the way to the back inside of the holds, that is where their is no support underneath (except maybe some foam maybe)
waterfreak said:The important thing is that you take care of the customer and stand behind your product.
It's just the way I do business.
whatever happened to:
Being the first guy to install footholds or reading more posts about installing footholds doesn't mean your doing it right or an authority on the subject.
BTW BK, my footholds are the same thickness as wammers.
I weight 230lbs , can plate to plate a roll and my footholds in Whitney are still as strong as the day I installed them almost 5 years ago.
