Mark44
Katie's Boss
- 100% one place
I"m on stock carbs, on last question
where do you set the idle screw when your tuning the low speed
I have the idle set very very low.
but where do you leave it when tuning, wont it bring down the rpms when your trying to tune?
You turn it up for low mixture tuning. You do that ONLY because you do not want to touch the throttle and you don't want the engine dying.
I got it, so how high should I turn the idle screw at first? About how many turns? Then back it down once the low speed is tuned, and the move on to high speed.
I find the easiest way to set the carbs is to ride!
For the low, you can get it close on the trailer. It should rev (light touch of throttle) easily and cleanly. Ride the ski and let it idle for a minute or so and hit it. If its rich it will "gurgle", and if its too lean, it will "gasp". Make the appropriate adjustments. Note that the low speed screws (mixture) are VERY sensitive and require small increments, no more than 1/8 at a time.
I'm sure there are some other opinions on this but this method has worked for me and my customers for years..................
FTR, I have adjusted lows on the trailer or tied to a dock...........works also but is not as accurate IMO...........no water drag or added water pressure from the ski, but it will get you VERY close, and sometimes dead nuts perfect.
I would love to get a tiny tach for tuning. Can you do it on the trailer w/ no load?
The low speed screw is for idle mix only, and is also the very first step in tuning the carb.
While your method may work, it is not ideal.
Why make it more difficult by riding it?
It is very very simple to adjust the low speed screw on the trailer (but in the water).
