tom21
havin fun
- clearwater FL
has anyone experienced a bad stator on their sxr? Or one that was starting to go. what were your symptoms????
well I have a few friends with a variety of setups so at first I didn't consider it. but after rejetting one and testriding it - you can feel a diff in the carbs in the way the ski runs/performs, but after some time it will hesitate and run crappy like it has water ingestion. this one has f/a and a timing advance. I have another that may be fixed but time will tell. and an sxi with the same symptoms.
it just hit me as I have a bad trigger coil on my sj and i had seen some posts about problems with timing advances. gonna remove it and try it again, but I was just collecting info.
sound like a failing stator- water intrusion like symptoms when you know there are none?
thanks guys- will check it out. was starting to think I was cursed with all these kawis acting up. worst part is they would run fine for a day and then next run like crap. so I do a little carb tweaking and all is good for a tank of fuel and give it back and everyone is happy for a few days. then same shiot!
here is a silly question. why would you buy and install a timing advance when you could just do like you were installing a factory pipe? they both advance 6 degrees and you don't have to take anything apart and deal with the front cover issues.?[/QUOTE]
Must use a advance plate with 03's.:chairshot:
as it's the old style electrical system
