sparkplugs !!!!!
slickchaos
Chaos on a SJ
Mass/NH
and yes i did a search..
Evidently last year i was using br9es in the ski as the prior owner had used them.
I went to the yammy dealership and forgot the plugs size and style and asked them to look it up in the system and he gave me the BR8es.
when i got back i realized they were different..
does anyone know which is recommended..
im running a bpipe with stock motor.. no other engine mods...
Mouthfulloflake
ISJWTA member #2
NW Arkansas
you shouldnt be running the ES plugs on a stock head, the stock head uses HS plugs.
B8HS is stock plug.
most aftermarket heads are thicker and require B8ES ( extended shaft)
the R in the number means its a resistor plug, and the 8 or 9 is the heat range.
cosander
Dallas/Fort worth
If the es plugs don't reach the piston then wouldn't they raise the compression by occupying more space?
