clicking wont start
I got a 750sx and it will not turn over. It makes a clicking noise. I thought it might be a connection or a ground but have checked them all. Could it be the starter?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
remove the spark plugs.
will it spin over then?
maybe the engine is locked up, or there is something hung in the pump preventing it from spinning.
it could be the battery, the solenoid, the cables, or the starter, or even the bendix is locked up.
Shonuff
I've got the glow
Memphis
It could. It is most likely the starter relay. Get into the electrical box and jump the nodes of the relay with a screwdriver. If it turns over, it's the relay. If it doesn't, then we go from there. (ground, battery, starter, switch, etc.)
What he said
Unfortunately these guys are right. It can be any one of those things.
Since you hear a clicking noise I would think the switch is fine.
I have had a bendix do that........otherwise I would say starter relay.......Obviously I would make sure battery is charged and cables are tight first.
But shouldnt he hear the starter spinning if he has a bad bendix? I would bridge the starter relay with a screwdriver and see if it turns over then
tor*p*do
Squarenose FTW
NW NC
could just be the battery.
mine went dead, and had just enough power to click the relay, not enough to turn the starter
Mouthfulloflake
ISJWTA member #2
NW Arkansas
not if the bendix is locked up, or the engine is locked up.
voltage test on the battery.
verify good cables to the starter.
then go thru the steps, its a pretty simple system.
well when my seadoo got flooded with water a couple days ago it did the same clicking thing till i pulled the plugs, it spun with them out and just shot out water. ive also heard the clicking with a low battery though
