dropped another piston.
What has you guessing at the crank?
Some information you might provide would probably help tremendously.
You know, engine, setup, compression, gas octane, ignition setup, etc etc etc.
Right now you're basically saying that your ski is green and it doesn't run. What's wrong with it?
Except you didn't even give us the color.
Shonuff
I've got the glow
Memphis
I guess we may be able to rule out the crappy Florida gas now.
What octane are you running and what is your compression? Are you detonating? This has not been a good 2008 for you, Mikey.
well heres what iam running. 701 with b pipe msd enhancer ada head rad fly wheel v force reeds reed spacer x metal water box, 94 octane. sorry for the lack of info before i rode the little bus to school.
Cross
X
WA
What carbs? Jetting?
A little more info as to how/when it seized? Were you at WOT? At idle?
DId yu have to bore the cylinders after each failure? Did you hone the cylinders with new pistons? Ports chamfered?
As you can see there are a ton of questions to be answered (and thats just the tip of the iceberg) before anyone can help you out to why you are having issues. The more info the better. Or you could just keep throwing pistons at it and see if it will fix itself!!!!
i did bore the cylinder after the last one drooped. the motor never seized up on me it was after a nose stab. i gassed it to come out of the water and she just shook a lot and didn't go any where. then i checked the compression and the rear cylinder went on me again:bs2:
keefer
T1
Tennessee
Maybe you have a air leak in that back cyl. I had an engine once that had a minor air leak and it kept eating the rear cyl. Too much timing, small air leak, go lean, deto, and boom.
waxhead
wannabe backflipper
gold coast
A pic of the piston would make it alot easier to actually figure out whats going on
