allright...no one has gave me a heads up on the relay jump thread in driveline, so I asked a friend at church and went about it in true "Darwinian" style. I almost put natural selection to work. I've got an analog TL that seems to be wired correctly. However, when I try to start it all I get is a loud click from relay.
The pics of my relay are far from great, but see if you can guide me. I tried jumping the starter wire side and the lanyard-on/off side. Both sides spit big sparks and the starter side made a huge pop/bang sound almost like a backfire and lots of ozone smell in the shop. I've got the all the fuel lines primed and a full tank and don't care much for sparks and bangs. Scared the pi$$ out of me.
I still get loud clicks out of relay when I try it start it. Batt volts read 12.7 and the starter worked last fall when i put it up. I took the starter apart and put new seals and exterior connects on it. My wiring is per the MSD schematic. I've got a few concerns with wiring and it's the lanyard they show seperate from the starter switch. I take it the starter switch they have listed is my OEM lanyard-on/off. I have an on/off toggle wired from brain (purple wire) to positive batt...no lanyard between the batt and toggle. Do I need that? Also, I have the lanyard-on/off wired as so: white/black from on/off to the pickup wires, and the red/brown from on/off to the relay pos. and negs. Might I need to reverse the red/brown? Do I have the white/black and red/brown going to the correct places? :smashfreakB:
