well, look at the big brain on you guys. Being an educated idiot (such as myself) did not have the starter grounded. So, I checked the starter on my bench...it works. Go figure. Now, I have to reinstall it, but need to go find an appropriate wire to do so. Augustaf, you said I need a 6 gauge wire from batt neg to starter. I've got like 3 leads coming off the neg already. Is it a bad idea to splice them all together (12 ga each)on one connector and then run the 6 ga individually to starter? This will help with the congestion going on at my batt terms.
The MSD is ground to the mounting plate with bolt/nut...should it be on the mani instead?
Thanks for the replies guys. I'd be trying to buy a starter right now if it wasn't for your help.
