I bought a wetjet carb and intake last year, and when it arrived it was gold, and a 44.
probably the same stuff, only CERTAIN wetjet engines had that 46mm carb, Ill try and find the thread.
I dunno.How would I know?
All I know is that a 46 probably shouldn't have the same throttle plate as a 44.
I have a 46 off of a Tigershark on my X2 the bolt hole spacing is wider and had to be dremeled out to work on the 44 manifold.I have a couple of those 46mm carb bodies laying around here. The # on the plate is#120 so it does use the same throttle plate as the 44.The caliper reads 46.5mm across the bore,It appears the very bottom of the carb has been enlarged 2mm in an area about 8mm from the bottom of the carb .There you go myth busted.
Yup, you have a carb from a Duo 300, the Kraze has the nice manifold by Westcoast w/ the 46 that has wide bolt spacing.
The Duo 300 came with a regular 61x intake and 44 SBN carb but just different colors, I've seen both silver and gold.
I bought 2 Duo 300's and thought they had the nice intakes, but no!
Good luck resolving the issue - I do have a WJ 46 with the wide spacing, if you want it. I got it from Team Scream but never used it - it's clean though. PM me.
I bought one of those early last year from the same seller. He sent me a 46 and the spacing was wider to match the intake. I sold it with the wetjet intake that I already had. Posted pics here.
http://www.x-h2o.com/threads/22319
He prob just sent you the wrong carb. He sells 38 and 44s too.
edit: the opening at the top is the same as 44, and the throttle plates are too. I thought I had a 44 when I first got it. The bottom is bigger on the 46.
Is that true for all 46s or just the wetjets?
