My ski is having trouble starting under a load. It is fine on the trailer. As on now, I have to roll the ski so the exhaust is out of the water for it to start. I have swapped carbs, all electrical, and still am having the same problems. Could worn out reeds be the reason for my starting issues? My ski also seems to be lacking a constant fuel flow when riding. It will have full throttle then go to an inconsistant powerband. If I rock the ski when riding it the power resumes and everything goes back to normal.
Could bad reeds be the issue here?
OR should I be trouble shooting somewhere else on the ski?
If the reeds are bad, how do I tell which ones to replace them with? Thanks to anyone that helps.
-Jake
-Jake
