teton
tetongravity.com
- Washington DC
Alright Ive been thinking of doing this for a while, now that my senior design project is over I have the chance to put it into action. here are my plans for the motor.
after looking at some 61x reed cages vs. the 62T I noticed that the actual incoming area of the 62T's is actually smaller (at least on the v-force 1's i have) the actual reed area of the 62T is larger, but I figured hell, I bet I could build a full 61x motor just about as strong as a 62t/61x motor. I have to give Matt-E's frankenstein build credit for getting me off my ass.
so here are the plans:
-61x/61x
-bore will be 83mm
-epoxying/heavy porting of the cases
-porting the cylinder for freestyle
-the carb will be a single 48mm full spectrum
-I will be lightening the stock flywheel based on finite element analysis on
solidworks (CMOS works) so I know where its the best to remove material
-heavy boring of the stock intake.....will require epoxying
and last but not least....let me know what you guys think.....a waterjacketed intake manifold.....no idea how beneficial this will be......but I will compare it to a bored stock manifold
Im hoping from a lot of feedback from you all.
-61x/61x
-bore will be 83mm
