budget surfboat/firstboat- comin along
brett
Ventura,ca
she's all stripped and ready.
this bilge pump/pisser setup is weird, can get rid of it? looks like a pretty big hole in the pump.
anyone need a 650 lol
wydopen
onthepipe
we took chads off on his square and now i think that with the hole there it dosnt get enough suction to push water for the cooling..he filled it with 5200 but it blew out..
brett
Ventura,ca
got new prop in, hull fixed, bracket area reinforced, and im waiting for a flywheel puller to put in different stator/ flywheel because the 61x motor i bought fried the wire somehow. electronics is not my forte so i dont know, but for some reason the stator wire got really hot and melted. i have a 62t flywheel/stator setup from my old motor i was gonna throw in there. anyone have any ideas on what caused this?
brett
Ventura,ca
i pulled the flywheel cover and it was a mess in there! i can see why the wires burned up. there was oil covering the stator. i got scared and thought a crank seal was bad but after closer inspection and cleaning im pretty sure it was the oil injection pump.
brett
Ventura,ca
new impeller in
quicksteer
brett
Ventura,ca
rn bracket and hood hooks installed. just got done puttin sj batt cable and switch cable to the blaster ebox. rn pole cut 2''
brett
Ventura,ca
got the motr in and ordered turf...then i got a call back. no more molded diamond till may ~10. we're almost done so im thinkin we'll go with waffle cut
brett
Ventura,ca
so freakin close!!!i need an RN pole bolt. makin the sn bolt work is becoming a nightmare and i think we fvked it up for good now
