wr/sj conversion help please
Officer Mike
TJ / SJ / JJ
Harveys Lake
hey i am going to put a waveraider 701 into a sj.
heres my questions as of now.
will the WR motor mounts work?
where can i get an oil block off..
the WR pipe wont work right cuase it goes to the rear maybe too big too. will my SJ pipe bolt to the 62t jugs? thanks guys
Officer Mike
TJ / SJ / JJ
Harveys Lake
so theres animosity cause ima "cop" ? or im in the military? or both? or none at all? someone tell me whats up?
anyone one care to help me out with my other build?
FL
Not sure on the motor mounts.
You can get the oil block off at atlantic jet sports, Riva, etc.
The raider exhaust won't fit. You can use sj/blaster exhaust, but you'll have to timesert the 62t cylinders and port match the exhaust manifold. I'm not sure if you can use the raider exhaust mani with the SJ pipe, but if it will bolt up then that will be the easiest way to go.
Officer Mike
TJ / SJ / JJ
Harveys Lake
thanks marz,
i honestly dont kno what timeserting is. i kno the sj is 8mm studs and wr is 10 so i imagin it has to do with that.
port match .. is there slop left to right or do i have to actually take metal out? thanks
njfl
X-H2
Mike, sorry for the delayed response. I did some checking on part numbers and they are indeed different. However, with Yamaha, there are only a handful of mounts. The SJ and FX-1 are definitely diffferent. The SJ has an angle. Can you post a picture of your Raider mounts? Don't you have a 2008 SJ? Just take a look at that to see if they look the same.
FL
Timesert is similar to a helicoil, just better. You are correct, the t cylinders have 10mm bolt holes. Actually the easiest thing to do would be to drill your x cylinder manifold holes out to 10mm. You would then have to also open up the openings in the manifold to match the cylinder.
Officer Mike
TJ / SJ / JJ
Harveys Lake
im still lost on the timesert/helicoil.. drilling and matchin not a problem. what if i bought a SJ after market pipe..same thing? have to modify that manifold? thanks
njfl
X-H2
In your case, the Timecert/Helicoil thing is very easy. You mentioned that you have a 62T cylinder, right? That has 10mmx1.25mm threads for teh exhaust. That happens to be the correct size already to accept the 8mmx1.25mm Timecert/Helicoil that is required for your SJ exhaust manifold. If you end up coming by, I can do it for you. I have the installation tool. Just pick me up some extra 8mm Helicoils, or pay me for the replacement (they're cheap):
http://cgi.ebay.com/ebaymotors/20-H...019QQitemZ290174396660QQrdZ1QQsspagenameZWD1V
njfl
X-H2
Not sure if you are clear on why the Helicoil is necessary. The SJ has provisions for only 8mm diameter bolts, whereas the 62T cylinder is expecting 10mm bolts. By changing the 10mm bolt size in the cylinder, you will then be able to bolt on your SJ exhaust with its 8mm bolts (OEM or aftermarket).
Officer Mike
TJ / SJ / JJ
Harveys Lake
now i understand, you just screw that on and its basically like changing the studs right? i never saw that before thanks.
about the mounts, i looked thm up and i know that the part numbers are different, but i read about someon else doing this and they said ( i understood it this way) that they did use them tho. if i have to buy sj ones, no big deal.
sneaky
a real mickelson
PNW
no animosity, found his comment above mine blunt, not helpfull and therefor funny.
thats all! sorry for the confusion, sounds like these other guys are on the ball tho! and thanks for serving, much appreciation and respect! :)
G
Goose
you can get some 8x1.25 helicoils and they will go right in the 10x1.25 threads on the
62t jugs without even having to drill and tap it
njfl
X-H2
I think you got it, but you're not changing studs, you're changing the threaded hole where your exhaust manifold bolts will go from 10mm to 8mm.
Officer Mike
TJ / SJ / JJ
Harveys Lake
yea i pretty much got. i havent taken it apart yet. its like the kawi with studs sticking out of the jugs right?
