Midlake Crisis
- Bakersfield, CA
Thought while I had my ski down for a top-end rebuild I would check out the rest of the drivetrain. My midshaft bearing just didn't sound as smooth as I thought it should, so I tore it down and it was filled with water. It doesn't really seem that rough but I am going to go ahead and replace the seals and bearing for good measure.
Here are pics of my impeller aka "the gravel pumper":
I have a 62T 701 motor (will be one over after rebuild) with single carb, stock exhaust. This impeller obviously needs some work, but if I get it cleaned up is it a good impeller for low-end acceleration, or should I buy something different? It is stainless, and marked "Skat-trak 6 3v".
