300/440/550 X-2 mods
Starting X-2 750 project
Looking for the best mods to do that work. Also, What can be done with the trim control? Can I move it to smooth the dash panel. I would like to cut the hood and fill the gas door in too. If you got any good mods and pics throw them on. Im looking for good ideas that work. Heres some parts that I have. Thanks for the help.
88 x-2
small pin 750
daul 40 carbs
R+D head
west coast pipe
bad bones water box
650 ign
alum engine plate
R+D scoop grate
Thanks, Does anyone have pics of cutting there hood flat and what to do with the trim knob? I would like to get rid of trim knob and fuel switch and smooth the top out. But like to put a trim lever on the bars. Just not sure how to hook it up inside the hull. Anyone with some trick ideas on it?
Zimmy just got an x2 & is doing the same mod that legdrag pete has for the trim. the old knob is used as a pivot point or something. I couldn't quite grasp all that he was saying because, the mickeys was getting to me. :friday:
maybe you can find some info on legdrag's setup.
cattledog
EH TEAM RACING
toronto canada
check the sticky in the x2 section called X 2 MODS it is really good everything is in their all mods covered
Vumad
Super Hero, with a cape!
St. Pete, FL
Shaving the hood is cosmetic only.
You should change the hood a bit so that it breathes from the back instead of the top left. The hood can block incomming water flow and keep it dryer.
You can probably move the hood latches a tad to make the hood seal tighter.
You can add hoses from the hood to the bottom so that the water that does come in is channeled down instead of falling freely from the hood.
Front sponsons will help the ski turn better and keep the nose up in the surf. Tom21 just finished a custom set for the X2 and Surfjet louie has a set for sale too.
Modifying the trim set up will help for freestyle. http://x-h2o.com/showthread.php?t=19267 Pete did this set up and it's a good idea. It uses a modified stock trim. I forget who but someone is selling a custom trim for the X2 for like $215
I wouldn't suggest cutting your hull until you figure out what kind of riding you want to do. Cutting the hull will improve the turning and the handling, but will cause the ski to handle even more poorly than it does at high speeds already. Make sure your ski isn't going to be for cruising or bouey's before you cut the hull. Cutting it is good for freestyle. Otherwise, go with the front sponsons and a D-cut rideplate.
You could also do the bottom mod like Crab did. It's in the X2mods thread. 24/7 is also making a part like what crab did that's pre-made you can just glue on. It would help with your carving and maybe improve your pop some.
Get something to improve your steering throw too. Aftermarket steering or a modified stock steering arm works.
The rest is mostly engine modifications, which the answer to that question is... as always... the more power... the better...
And as I always say, don't modify the ski unless you know why you're doing it. If you have never ridden a X2, slap it together and try it out for a few rides. Then you decide which mods are going to work best for you.
Vumad
St. Pete, FL
And no, you can't move the trim to make the dash look prettier. The only way to do that is to change out the trim cables with something different. The techniquie that Pete used will work the best and be the easiest. Anything else will be more work that it is worth.
You could do a set up like they do on the superjet, which will consist of going with a long bicycle cable (but made of stainless steel) that would go all the way from the handlebars to the trim with one single cable. The problem you will have with that is you have to find the cable, then you have to modify the trim tubes so that the cable stays water tight, because the cable you will use is different than the stock cable set up.
I think the guys using bicycle style cables are just going with smaller trim tubes and filling the tube with 5200 to keep it sealed. Not really the way I'd like to do it. I'm open to other suggestions.
