My X2 exploded
Vumad
Super Hero, with a cape!
St. Pete, FL
So how much did you cut apart and how much of it did you just seperate the two halfs?
I cut 3" off the back of the hull. Just before the bolts that mount the ride plate. The hull is going to be shortened.
I cut off the rear bond rail. The bond rail will be moved so it was a waste of time to try to split it.
I cracked the bulk head. It sits in a channel and was impossible to seperate. I am probably going to do something different with it anyway.
The rest was split. I doubt you could spli an X2 without destroying it in some way. Splitting the rear rail is probably impossible.
shawn_NJ
Chasing waves.
Daytona Beach
Hey Vumad, bumping your old thread a year later. Any chance you weighed the bottomdeck (or top)? When you cut this thing to pieces?
