Here is a copy of my email to jetinetics tech support:
I am planning on using your yamaha 61x flywheel with a MSD Enhancer CDI ignition on my 62T yamaha superjet engine. I am also planning on using a refurbished 61x stator from Jetskisolutions with this setup. I have read old posts on pwctoday.com and x-h2o.com about how your flywheel and the refurbished stator can both change the timing because of stronger magnets in your flywheel and larger wires on the stator.
Do you have any recommendations on how to best set the timing with this setup? I have searched the web for info on setting the timing on a 2 stroke engine to no avail. Any how-to information you could give me, or other resources for this information you know of, would be greatly appreciated. I know that rotating the stator will change the timing and what TDC is. I don't know which cylinder to look at for TDC or if there are any timing marks on my engine that I should use.
Thank you,
Shane McDonald
Any comments or suggestions on what else I should ask?
