The Official 66e freestyle/freeride thread
RiverRat
Louisville, Ky
yes mine is up and running
weather is keeping me from getting the carbs dialed in but it rips!
blows my full ltd sxr away on acceleration!
its well worth it!
cant even think of what a 927 will be like
it was @ daytona last week for those who attended to see
vomit
Have any vid of the ski up and running?
Lakeman
Stand Up All The Way
Wichita, KS
927 motor/ SEXY
I thought I would post some pic's of a new motor of mine. It has been in the works for over a year and it arrived in Nov 07. I will post a build on this ski in a few days to explain more. SO SO SEXY. I want to sleep in the garage about every night.
Dale
they are definatly 1200cyls (66v marked)..and have been resleeved....no nikasil
the 66V ports are different than the 66E ports. A common mod on the GPR1200 is to use the 800 jugs (it's like a mid port job).
Edit: the 41ccs on a 66E motor are 150psi
for later on here are the numbers and psi
41cc: 150psi
37cc: 170psi
35cc: 180psi
31cc: 200psi
crammit442
makin' legs
here
I wonder how much punishment an offset keyway can take in a watercraft because watercraft have no transmission to take up the shock when the driveline comes unhooked then hooked.
Since the key ONLY locates the FW and the taper is what keeps it from turning, it should have no effect in any way. Assuming the tapers mate well.
uh, so if the taper is what keeps it from turning. why is it that when the key shears that the ski runs like crap because the timing has changed due to the fly wheel being at a different degree point on the crank???
41cc: 150psi
37cc: 170psi
35cc: 180psi
31cc: 200psi
Jeff told me that in THIS application the rider would not notice the difference in jugs...
the only difference is in the center transfer....the 1200 cyls tach out @ +50 rpm's as compared to the 800 jugs..
I have 41cc domes, I'd like a set of 37's if those #'s are accurate....170 psi is perfect IMO..not too much, not too little..
crammit442
makin' legs
here
uh, like I said. The key is ONLY there for FW location/timing. If something keeps the motor from turning during cranking(water) the key is the fusible link(for lack of a better description) and it's shearing allows the FW to slip on the taper. Drill presses, machine tools(morse/jacobs tapers), some engines, etc do not use a key. Do you really really think that little key is the only thing keeping the FW from slipping? Tapers provide a huge amount of contact area(friction/shear). Tapers can transmit huge amounts of torque. That's why many builders like to lap the taper surfaces. It ensures a more perfect taper contact area......uhhhhhhh.............
http://en.wikipedia.org/wiki/Machine_taper
Those numbers are from a Riva price list year 2000. On my GP800 the numbers were right about dead on from that sheet.
No, I do not think that key is the only thing that is keeping the flywheel in place. Just looking at it from a different angle. Yes, I have heard of people even using loctite on the taper to help seal the flywheel on. But without the key on it, the fly wheel will be more prone to keep timing than without.
Think this is more of a "they go hand in hand"
I dont think a drill press spins 6500 rpm's do they??
I have been doing that for years, even when I put on a MSD Charging flywheel that did not have a steel hub........... Dooohhhhhh.... that was a mistake.........
