Well, it's been a long time coming but in the end, it was well worth it! I inquired to Chris Maros quite a while ago after doing some business with him... pre sale of his 24-7 PWC division about a conversion hood... I actually wasn't serious enough about it at the time and moved on. Bout a year later, and had since ridden Tim's 24-7 conversion sj that he had bought... I called Chris outta the blue about some footholds and misc stuff, and he informed me about the pending sale of 24-7 that was going down in two days. Well, I inquired about a hood again and the only one he had left was his own carbon fiber one. We struck a deal and I felt fortunate enough to have scored it.
Chris' own steering system needed some modification as he had found some faults in it so it sat my garage for a while. Tom Rill (Tom21 here on the X)- member of our very own Gulf of Mexico Duckpond/ Westside Massive Ride group and owner of professionaljetskirepair.com finally undertook the job of machining the steering system and proceeded on with the rest of the build from there on out. IT FREGGIN ROCKS!:fing02:
Major thanks to Tom! As the rest of the guys who have joy ridden her can attest... it turned out sweet! Thanks for taking the lead man... you're a master of modification! Job well done! http://professionaljetskirepair.com/
Additional thanks to Danny Riese (flacarandcycleguy here on the X) for the fantastic work and paint job on the hood as well as the "out of warranty touch ups!" From what I can see, and hear for that matter... we have a star in the making!
Also much thanks to fellow local Pat @ Xmetal for the fabrication and welding of the bracket. Good stuff as always Patrick! http://www.xmetalworks.com/
Thanks to Kevin Collins at http://Legdrag.com
And lastly, to Chris Maros for all the R & D and for producing such a fine product! You're a master Innovator!
2004 SJ H20-X Conversion
Chris Maros 24-7 carbon fiber H20-X Conversion Hood,
24-7 footholds
24-7 lowered nose
24-7 steering system modified by Tom Rill
24-7 bracket fabricated/ modified by X-Metal
Blowsion Tubbie 2's
stock 701 w/ ADA billet head
stock 38's with JSS Primer
dual cooling
Jetworks flow control valve
Factory limited B pipe
MSD
Wet Wolf cone
Skat Trak 13-18 cutback
Carbon Tech reeds
Dupont paint/ BLK (hood)
Highroller front Foothold
Riva 27' bars
ODI Grips
XMetal Throttle
quick disconnect
24-7 aluminum battery tray
Hydroturf
Hoodstraps
24-7 footholds
24-7 lowered nose
Blowsion Tubbie 2's
dual cooling
MSD
Wet Wolf cone
Carbon Tech reeds
Riva 27' bars
ODI Grips
XMetal Throttle
quick disconnect
Hydroturf
Hoodstraps
