FX-1 a few fx-1 build pics.
LIVE2RIDE Powersports
Live & Die 2 Ride
WorldWide
i still have alittle more work before painting. first im cutting the tray sides down alittle like a x-jet look, second the hood where the fire ext goes is being cut out then making it flat. im not running the pole through the hood just getting a rick roy type pole "making it", then doing alittle cutting where the back tie hole is the make clearance for the trim. any thoughts?
DsmRacing
Wannabe Freerider
Tampa
Nice build, I have an FX-1 as well, so I will be watching this build as well. Did you install tubbies? Looking forward to seeing how you lower the hood, trim, what pump setup, motor combo, etc...
Live & Die 2 Ride
WorldWide
no tubbies yet, its for flatwater and as of now dont see much chop or surf. plus i like how squirlly they are.
on to the hood im going a different route as slug did on his. its hard to explain so i will just post pics soon. thanks
Live & Die 2 Ride
WorldWide
if your going for a flat water backy, you need to start looking at a pump modification, intake track mod also........
ya i am doing the pump mod just not sure which one. i have a few 650sx pump laying around so that may be my way. do the 750sx pumps work in them i have 2 of them too? i also have a 144 raider pump but may be to long.. thanks
