ignition ???
gunrgood
Almost ready
Macramento
what are our choices for after market ignitions for the sxr. i know of the 3that blowsion offer. anything else? how do they rank?
Advent
SXR Digital CDI-9R
MSD
Proformance1
Liquid Insanity
New York Crew
I have the 9R, and so far so good. No complaints except that you have to put a disconnect in or it will drain your battery if you don't unhook it. There is a new programable via a laptop from someone, I'll see if I can find it. Don't know a thing about it though. Also there is total loss.
Found it http://www.sx-r.com/xxx/igni.html
I think waxhead does an ignition for them as well.
Not sure of his web address, think its:
waxracing.com, but I'm sure you could PM him and he'd get back to you
IceRocket1286
Metro Detroit
Why do you want an a/m ignition? What other mods are done to your ski? If you have a full blown superstock or full limited setup you'll probably need it, but dont get it otherwise. You'd be throwing money away if you dont have much done to your ski and buy an ignition. I have a full limited and run an MSD enhancer, only because without it I hit the rev limiter.
Cross
X
WA
What RPM are you turning in your Limited? I was under the impression that the rev limiter on the stock sxr was around 8000 rpm. You shouldn't be running anywhere close to the rev limit on a limited boat.
You could gain some better bottom end punch as well as some RPM's on top with an aftermarket ignition (advent, blowsion, igni-power, etc).
tell him what u have for mods and he will give u good curve sets, that ign will hold 4 diff ones,be aware of alum flywheels with this se up some dont work due to the magnits..
5810
WHERE-THE-SEAT-AT
Knoxville TN
I just put a cdi-9r in mine, & what a diffrence it made. i ran curve 5 which is almost stock & the ski ripped, cant wait to try curve 7 ski should be a monster. :woot:. Worth every penny.
